Z1300 Turbo
Bevelhead
Z1300 Turbo
#1 PostAuthor: Bevelhead » Tue Sep 01, 2020 2:05 pm
A friend turned up on this while I was visiting another mate, he did all the work.. including fitting the turbo (from a Peugeot diesel), its got low compression pistons which take it out to 1440cc.
Julian_Boolean
Re: Z1300 Turbo
#2 PostAuthor: Julian_Boolean » Tue Sep 01, 2020 3:51 pm
How does that work with what looks like the standard airbox and carbs?
There was a bloke in Clacton in 1990 who had a turbo'd Z1300, it also had a mono shock and chain drive conversion.
rickm
Re: Z1300 Turbo
#3 PostAuthor: rickm » Tue Sep 01, 2020 3:52 pm
Nice work.
Is that an open exhaust coming out of the turbo at the front?
I bet that's quiet :rock
H2B GPZ900R
Bevelhead
Re: Z1300 Turbo
#4 PostAuthor: Bevelhead » Tue Sep 01, 2020 4:09 pm
Julian_Boolean wrote:How does that work with what looks like the standard airbox and carbs?
It has carbs, but it has a plenum chamber that's made to look like the standard airbox. I'm told fitting a turbo to an injected bike is pretty easy, not so for a carbed bike.
Bevelhead
Re: Z1300 Turbo
#5 PostAuthor: Bevelhead » Tue Sep 01, 2020 4:11 pm
rickm wrote:Nice work.
Yes I think so, but it didn't sound that loud when it was revved. There's a short vid of the bike here..
https://youtu.be/1xnb9NBaA_o
Tony
Re: Z1300 Turbo
#6 PostAuthor: Tony » Tue Sep 01, 2020 5:48 pm
That looks wicked I wouldn’t mind a spin on that
Julian_Boolean
Re: Z1300 Turbo
#7 PostAuthor: Julian_Boolean » Wed Sep 02, 2020 8:03 am
That's my understanding as well, and having multiple carbs is supposed to be more difficult than a single carb, Yamaha did it with the XJ650 Turbo and had to seal the carbs.
Re: Z1300 Turbo
#8 PostAuthor: Pigford » Wed Sep 02, 2020 10:15 am
Yeah, "blow thru" set up.
Turbo's are often fairly quiet as the exhaust note is broken up by the turbo.
