Ignition keys
Ignition keys
How do you tell what number key your ignition is if you don’t have a marked key? Seat lock has the number does the ignition, I know not on the face but anywhere else? Thanks
Re: Ignition keys
harri183 wrote:How do you tell what number key your ignition is if you don’t have a marked key? Seat lock has the number does the ignition, I know not on the face but anywhere else? Thanks
seat lock has the number on it.
Curlywurly
Re: Ignition keys
Ignition switch has it stamped on the vertical part of the barrel if it is still the genuine one, you can't see it until you take it out
Re: Ignition keys
Users browsing this forum: sockpuppet and 37 guests
