Non starter
Grimreaper
- Regular Poster
Non starter
Hi troops, hope you can help, was out on my Z1000R2 today, stopped for 10mins, went to go again and pressed the electric start and nothing?????? Al fuse are ok. Any ideas ? Thanks Mike
Re: Non starter
Dodgy connection on wiring - could be anything, but check obvious stuff like kill switch not grounding at bars, fuse box area & associated wires......etc.
Start wiggling wires - one area at a time & try starting each time - may isolate problem if lucky?
Good luck!
Good luck!
Users browsing this forum: No registered users and 106 guests
