APE oil breather cover problem .........
piersz1
#1 PostAuthor: piersz1 » Tue Apr 29, 2008 6:49 pm
hello. ive fitted an APE breather replacement cover to my MK2 z1000, but,
im loosing an awful amount of oil through the breather. i can only assume its being thrown up through the two holes, left by removing the old breather, by the gearbox cogs inside as they are directly below the holes..... any suggestions ??????
thanks
debben1
#2 PostAuthor: debben1 » Wed Apr 30, 2008 11:35 am
Hello PiersZ1, are you using a catch tank ? these are designed for use with a catch tank, but even with this catching the oil there should not be much oil being thrown up, the highly tuned race bikes are connecting an electric vacuum pump to these to suck away crankcrase pressure, crankcase pressure will limit high rpm power, even with a pump sucking on the breather we do not loose much oil. If oil is being blown out of this breather then it would be more likley that there is excessive crankcase pressure, this can be caused by worn piston rings or a headgasket leaking into the camchain tunnel, it could also be if the crankcases are being overfilled with oil, a fairly common mistake is that sometimes owners fill the oil to the top level of the sight glass, the oil just needs to be between these level lines and on the race bikes we never fill above the lower line. I hope this gives you a few ideas, Best Regards, Steve
piersz1
APE HELP !!!
#3 PostAuthor: piersz1 » Wed Apr 30, 2008 7:07 pm
CHEERS STEVE, OIL OVERFILL MAY BE A CAUSE THEN ! I FILLED TO JUST ABOVE THE TOP LINE AS I FITTED AN OIL COOLER AND IT WAS SUGGESTED TO ME THAT A LITTLE MORE OIL IS NEEDED...!! WRONG ?
THANKS FOR THE ADVICE.....
#4 PostAuthor: Pigford » Wed Apr 30, 2008 8:38 pm
Piersz1, with an oil cooler, it also depends on which way the cooler take-offs are mounted.
Mine are mounted so they come off the top of the cooler matrix, so the cooler stays full of oil when the engine is stopped. I then check oil is in middle of the level lines :wink:
This means I can use the cooler as a small reservoir which increases the oil capacity by a bit :P
RALPHARAMA
#5 PostAuthor: RALPHARAMA » Wed Apr 30, 2008 10:02 pm
Biscuit boy isn't just a pretty face! :D
Ralph Ferrand
debben1
#6 PostAuthor: debben1 » Wed Apr 30, 2008 10:32 pm
I like the steering stops, clever solution to decreasing steering lock to clear bigger fork legs and cooler :wink:
piersz1
olympic shirt lifting
#7 PostAuthor: piersz1 » Thu May 01, 2008 7:33 am
thanks for all the advice. that nice lady must have icredable stamina and arm muscles, ive been watching her for 4 hours and she hasnt missed a beat......... :lol:
#8 PostAuthor: Rich » Thu May 01, 2008 6:16 pm
Also when you mount the cooler like that it gets oil to the cams quicker.
