Fuse box lid
Grimreaper
Fuse box lid
#1 PostAuthor: Grimreaper » Fri Sep 25, 2020 7:12 pm
Hi folks. Does anyone have a fuse box lid for a Eddie lawson replica Z1000R I could purchase please? I presume it's the same as the z1000J. Thanks Mike
Re: Fuse box lid
#2 PostAuthor: Al » Fri Sep 25, 2020 8:03 pm
Not what you asked for but possibly one for the Christmas stocking!
https://www.cmsnl.com/kawasaki-kz1000r1 ... 260041011/
If you are prepared to move a little away from standard, vehicle wiring products do a passably similar one for less than a fiver. Its vaguely the same but will require you to chop youre wiring and it has modern blade fuses. For info; it also sits at a slight angle because of the offset position of the mounts. Its water sealed too.
https://www.vehiclewiringproducts.co.uk ... e-fuse-box
Grimreaper
Re: Fuse box lid
#3 PostAuthor: Grimreaper » Fri Sep 25, 2020 9:21 pm
Thanks Al, trying to keep it as original as possible but might be worth a shot. Cheers Mike
jimmock
Re: Fuse box lid
#4 PostAuthor: jimmock » Sat Sep 26, 2020 7:54 am
I just noticed your post.
I use the name Grim Reaper in 2 other clubs / forums I'm in !!
We might be cousins!!
Jim.
Jimmock. :wnkr
I hate people I don't like !
MikeP
Re: Fuse box lid
#5 PostAuthor: MikeP » Sat Sep 26, 2020 8:13 am
They're still available from Cradley Heath Kawasaki 26004-1011
Grimreaper
Re: Fuse box lid
#6 PostAuthor: Grimreaper » Tue Sep 29, 2020 7:02 pm
Hi Jim, my surname is Reaper, :D thanks Mike I will contact them.
Users browsing this forum: MikeP and 35 guests
