I can't for the life of me remember where the two overflow pipes sit (2 x 92059-084). I've got them attached OK to the carbs but do they just point up loose toward the airbox? Any pics would be appreciated.
Also, is there a favoured attachment position for the overflow hose clamp (92037-134)?
Any help much appreciated as the carbs are going in tomorrow.
Carb overflow pipes and hoses
Z1-B, 360bhp ZX1000NGF
- warren3200gt
Re: Carb overflow pipes and hoses
The two that point up are breathers not overflows. You can just take them up and back into the top of the airbox
Cheers Warren. Do you know where the hose clamp goes by any chance?
- warren3200gt
The small loop goes around the engine to battery earth strap. The big loop has the 4 overflows through it. All sit down by where the earth strap is bolted to the engine.
Brilliant! Many thanks for your help.
