Hello Team:
I have recently upgraded to Accel 3 Ohm coils/wires and a Dyna-S ignition. I get two different opinions. One is to remove (loopback) the two Ballast resistors? One is to leave them alone?
Does anyone know for sure?
Both the '78 and the '80 model z1R have these Ballast Resistors. The '78 model had factory points. The '80 model had factory CDI.
Thanks.......CwiseGUY
'78 z1R question about Ballast Resistors
- Attachments
- images.jpg (5.44 KiB) Viewed 2534 times
- warren3200gt
Re: '78 z1R question about Ballast Resistors
This what google has to say about it.
"Is a ballast resistor necessary?
And while ignition coil life may be compromised without a resistor, the additional secondary voltage (at the spark plug) is increased which generally improves power. So does your application require a ballast resistor? Quite simply, if your ignition has breaker points the answer is yes; if not, the answer is no"
3 ohm coils?
Bin it
Bin it
With 3 ohm coils, it aint necessary, put it on one side or bin it
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
Interesting explanation regarding BR's here
https://www.randakksblog.com/ballast-re ... components.
Specific to the Hobnail GL1000 and references the Lead Boot but offers useful info on testing etc if you must have one.
Z1-B, 360bhp ZX1000NGF
Yes, 3 Ohm Accel coils.chrisu wrote:3 ohm coils?
Bin it
Thanks. Cwise
Thanks, I read that.steve452 wrote:Interesting explanation regarding BR's here
ANyway, the thing is this (twin) resistor is not attached in the circuit to the coils themselves. The schematic has them going through the lighting. They are called Ballast Relay Regulator Resistors.
I notice some of the other schematics, kz1300 for instance have a resistor in the circuit with the coils.
Of course, all a bikes wiring trickles over to a COMPLETE circuit.
Thanks, Cwise
Thanks for the info, Cwisewarren3200gt wrote:This what google has to say about it.
Thanks...CwiseKeithZ1R wrote:With 3 ohm coils, it aint necessary, put it on one side or bin it
