ZRX1100 Fork spacer 92143-1065
scott
Junior Section leader
#1 PostAuthor: scott » Mon Feb 01, 2021 11:51 am
Would anyone happen to have two ZRX1100 Fork spacer, 92143-1065. Unfortunately someone has removed mine and thrown them away to fit progressive springs. Now i'm fitting linear springs they need the spacer back in.
Re: ZRX1100 Fork spacer 92143-1065
#2 PostAuthor: chrisNI » Mon Feb 01, 2021 1:57 pm
Shouldn’t be the hardest thing to get made as a last resort if you had the id and od :shock:
scott
#3 PostAuthor: scott » Mon Feb 01, 2021 2:34 pm
That’s exactly what I require Chris. I have the difference between spring lengths, this gives me the tube/spacer length. OD is probably the same as spring width and ID maybe 4-5mm short of OD.
#4 PostAuthor: chrisNI » Mon Feb 01, 2021 4:39 pm
Scott length is on the parts diagram - 55.5
scott
#5 PostAuthor: scott » Mon Feb 01, 2021 5:34 pm
Chris, the length of tube/spacer?
#6 PostAuthor: chrisNI » Tue Feb 02, 2021 12:08 pm
scott wrote:Chris, the length of tube/spacer?
COLLAR,L=55.5 92143 92143-1065
Kawasaki are quite good at giving lengths of bolts and spacers, certainly compared to Suzuki diagrams.
scott
#7 PostAuthor: scott » Tue Feb 02, 2021 12:12 pm
Thanks Chris.
Current spring(progressive) =400mm long
Standard spring =346mm
Standard spacer =55.5mm long
K Tech Linear spring =330mm
70mm long spacer required with the linear springs.
