Carb mixture screw thread size.
Gus
#1 PostAuthor: Gus » Wed Feb 24, 2021 9:40 pm
Evening Amigos.
I've managed to get a seized mixture screw out but still have some debris to clear out from the threads.
Once this is done I want to buy a tap to run down to clear any FOD.
Looking on the net I have seen thread measurements of M6x0.5 but also a dimension of a mixture screw thread of 5.9mm dia.
Would I be correct in thinking the tapped thread size is indeed 6x0.5 and the screw is merely 5.9 for clearance?
Thanks in advance.
Gus
"Set the GRINDER on it"
Re: Carb mixture screw thread size.
#2 PostAuthor: kev edwards » Thu Feb 25, 2021 8:09 am
Is this pilot fuel screw (underneath front) or air (on the side)? if underneath fuel screw 5mm x0.5, don't buy cheap taps either.
Gus
#3 PostAuthor: Gus » Thu Feb 25, 2021 9:35 am
Hi Kev.
Sorry they are CV carbs off a Suzuki 2001 - 2006 Bandit Mikuni BSR36.
I suppose I was thinking there were standard type thread sizes across carbs
Gus
Users browsing this forum: Bing [Bot] and 97 guests
