Oxford Heated Grips. Free of Charge if of any use to anyone for parts. Removed from my RS but had to cut the wiring to remove, and cut the left bar grip as it had been glued on.
Everything you see in the pic (missing left grip and the wiring has been cut). Worked fine before I 'removed' it.
Oxford Heated Grips. (Parts).
