Z2 750 Bore service limits
Anyone know what the cylinder bore service limits are on a Z2 750, bore is 64mm just checking on wear limits whilst tidying up a few things. I see the Z1 900 is standard 66mm with a wear limit of 66.10mm. Thanks.
- DogsbolloxofZ1B
Re: Z2 750 Bore service limits
I’ve restored a few Z2’s. Yes 0.004” would be the point of a rebore.
If you use IMD pistons/rings these are made from superior materials and the bore would be skirt OD (measured at right angle to small ends) + 0.0015-0.002”.
DogsbolloxofZ1B wrote:I’ve restored a few Z2’s. Yes 0.004” would be the point of a rebore.
Thanks for the info, very much appreciated. Apologies for the delayed reply from me.
