MK2 Ignition coil resistance
shorty
#1 PostAuthor: shorty » Sat Apr 24, 2021 2:00 pm
Hi,
I have purchased a pair of replacement ignition coils, on checking the resistance they are 5.3 ohms. Will these be ok to use, if so do I have to remove the ballast resistor and also what is the other component by the horn which the ballast resistor is connected to?
Thanks in advance.
mark burch
Gavin
Re: MK2 Ignition coil resistance
#2 PostAuthor: Gavin » Sun Apr 25, 2021 12:09 pm
I believe ballast resistors are only needed on low ohm coils, you remove it when using Dyna 3ohm coils.
Z1000 MK2
Z1300 DFI
Users browsing this forum: No registered users and 97 guests
