Hi
Anyone know of a supplier for the rear brake master cylinder square section o ring, I know redline supply them in the US but wondered if anyone has found a british supplier, apparently the measurements are OD 52 mm. The height is 2,85 mm, the width is 2,35 mm.
Thanks in anticipation.
Windy
1977 z1000a1 rear master cylinder o ring
- new poster
Re: 1977 z1000a1 rear master cylinder o ring
Hi Windy
I see you joined the club almost one year ago.
This is your first post and you didn't intruduce yourself.
On this forum, and on others, it's a custom to introduce yourself shortly and eventually to post a picture of your bike(s).
If you start with a question, you don't make a good impression...
I don't write this to lecture you, I only write this to help you to get an answer from people who know where you can find the part you're looking for.
Greetings from Belgium
Zpower should sell them. The preferred supplier, if you are a full paid up member you get a 10% discount
There is nothing special about the O ring.
They do wear and give odd measurements when old.
Just go to your local bearing supplier and they should be able to help.
