Float valves
harri183
Float valves
#1 PostAuthor: harri183 » Mon May 17, 2021 7:35 pm
Trying to work out what is what in my carbs, pot 2 was pissing fuel out so have stripped them all down and cleaned everything. Looking at the parts diagram it looks like the needle float valve are not the originals. They have 2.5 on the side and the filter is the small black one not the big domed white one and the kit that I bought to replace them says 2.3 on the side. So far I have cleaned the originals and just replaced the o rings. Also waiting on a float as one is damaged. Any ideas what’s what and which set up I should go for, what was in or the new rebuild kit and but the correct filters?? Cheers
