Z1R D3 Tank cap
750 R1
Z1R D3 Tank cap
#1 PostAuthor: 750 R1 » Tue Jul 27, 2021 12:09 am
Sorry guys I also posted this in the bike help section, I meant to post here.
I'm chasing a Z1R D3 tank cap, the one that screws directly into the tank, not the one that screws to the little welded on bracket, I have one of those in perfect condition I'd like to possibly swap if anyone has the cap I'm chasing, or needs the one I have. The main difference between the two caps is the length of the lock section of the cap.
I have a cap to suit the top tank, I need one to suit the bottom tank...
d3 1.JPG (127.56 KiB) Viewed 5178 times
750 R1
Re: Z1R D3 Tank cap
#2 PostAuthor: 750 R1 » Wed Aug 04, 2021 12:59 am
Bump
750 R1
Re: Z1R D3 Tank cap
#3 PostAuthor: 750 R1 » Fri Oct 15, 2021 12:43 am
Still chasing a Z1R D3 tank cap....
750 R1
Re: Z1R D3 Tank cap
#4 PostAuthor: 750 R1 » Fri Oct 15, 2021 11:52 pm
So apparently the cap I have is for the 1978 Z1R D1 replacement large tank, so any D2, D3 large tank cap will fit...
scott reid
Re: Z1R D3 Tank cap
#5 PostAuthor: scott reid » Wed Oct 27, 2021 6:19 pm
Hi, I have a z1r tank cap, but I don't know which type I have. Can you give more info, or sizes, or another angle of photo?
Scott
750 R1
Re: Z1R D3 Tank cap
#6 PostAuthor: 750 R1 » Sat Nov 13, 2021 11:33 pm
Hi Scott, I've sent you a PM mate....
Actually I've sent a couple of PM's, I could only add one picture per PM for some reason...
750 R1
Re: Z1R D3 Tank cap
#7 PostAuthor: 750 R1 » Sun Nov 14, 2021 2:48 am
For anyone that's wanting to know, the first pic is the cap I have , It doesn't fit, the second pic is the one I'm after...
scott reid
Re: Z1R D3 Tank cap
#8 PostAuthor: scott reid » Sun Nov 14, 2021 8:57 pm
Hi 750 R1, unfortunately the one I have is the same as the one you already have.
Regards
Scott
750 R1
Re: Z1R D3 Tank cap
#9 PostAuthor: 750 R1 » Sun Nov 14, 2021 10:05 pm
Bummer, Thanks mate....
750 R1
Re: Z1R D3 Tank cap
#10 PostAuthor: 750 R1 » Fri Dec 03, 2021 3:07 am
Bump, still looking..
