Hi,
I’m after a fuel level sensor.
The bike is a GPZ1100B1 but it’s converted to carbs. The tank I’ve got for it was on a Z1100R so has a petrol tap and the fuel sensor is different. It might be the same sensor as a GPZ B2 and maybe even a Z1000J.
It’s the sensor with 6 mounting holes not 5.
I’ll also ideally need the plastic cover for it as well.
The part number for the sensor might be 52005-1026
If anyone has one they would sell please let me know as Kawasaki don’t have them and I can’t find one anywhere
Fuel level sensor
Re: Fuel level sensor
Looks like the plastic cover is available even if the gauge is not. Normally they just fall off so unlikely to find one if you do get the sender / sensor.
14025 140241434
The gauge unit for the six bolt version appears to be 520051061
https://www.cmsnl.com/kawasaki-z1100r1- ... TYxLZ1KiUk
The 'fits these models' list shows up some years of GT550 so perhaps this one.??
https://www.ebay.co.uk/itm/304103440311 ... SwTgJhFNDS
I’ve found this from CMS.
https://www.cmsnl.com/products/gauge-fuel_520051026/
Has anyone used CMS before ?
I have used them a couple of times in the past. Postage has always been expensive, probably more so now. However they are pretty good to get spares off, albeit as a last option.
I bought the oval plastic cover for my B1 last year and got it from Cradley heath Kawasaki.
Rob
Rob
JimBoUK wrote:I’ve found this from CMS.
Yes, quite a lot. As the man says, the postage isn't cheap (it gets more reasonable the more you buy, if that makes sense) and the stuff can take a while to arrive but they are very reliable and prices tend to be fairly competitive. They often have a bit that you cannot find elsewhere, especially for Yamaha. Recommended.
Olly
Lemmy
Lemmy
Thanks guys.
I’ve ordered one from CMS
Users browsing this forum: Bing [Bot] and 54 guests
