I have read on here keyster kits are the ones to go for . I have read from experienced persons the only things that need replacing aside from the gaskets are the O rings from these kits ?. Is there cheaper supplier of the O rings needed other than buying the complete kits where most of the parts will potentially not be used ?. Any information or sign posting would be very much appreciated.
Z900 A4 carb rebuild parts
Re: Z900 A4 carb rebuild parts
I rebuild carbs very regularly. I use and recommend Keyster kits.
As a minimum you will need bowl gaskets and o-rings. Often you need the float valve. Once you need gaskets, o-rings and float valve, it's often cheaper to buy a complete rebuild kit.
You may also find that on the z900 carbs you will need new fuel tees. there is nothing wrong with using the Keyster main and pilot jets.
I would always prefer to keep the OEM need and needle jet - I'd only change them if they are worn.
You won't know what you need to replace until you strip and inspect.
Also you sometimes find poor running because the sealing rubber on the end of the plunger of each choke is degraded. I use Rob Meggit for this who can replace those rubber seals.
I sell viton petrol proof bowl gaskets that I have made in the UK. These are a fit an forget solution as they don't degrade like paper ones. (Some of the keyster kits have rubber based bowl gaskets included, but it seems a bit pot luck.
In summary, sorting a set properly takes quite a bit of time, effort and money.
Do get in touch if you need any help or advice.
You can see some of my carb work here:
https://www.facebook.com/airevalleyclassics
Thanks for the information and will take you up on the offer of advice and enquire of you the parts you sell
