J motor into an early frame
Andy M
#1 PostAuthor: Andy M » Fri Sep 17, 2021 10:16 pm
I am sure this has been done a few times . Just asking if a J motor needs much work or what is needed to fit in an A1 frame . Thanks
KWACKERZ1
Re: J motor into an early frame
#2 PostAuthor: KWACKERZ1 » Tue Sep 21, 2021 7:50 am
Yes it can be done, the length is very similar and it will go.
Some people only use the one front mount of the J but personally I would add a lower front engine mount to the frame as the J has two.
Andy M
#3 PostAuthor: Andy M » Sun Sep 26, 2021 5:49 pm
KWACKERZ1 wrote:Yes it can be done, the length is very similar and it will go.
Thanks.
