As the heading says, I need to purchase a crankshaft for a Z900A4. Prefer to get a good one but any condition considered: I have an existing crank which has wear on the generator end of the shaft (where the bearing sits) so need either a good condition crankshaft or something not so good, so that I can replace the tapered left hand side from the web/counterweight to the generator taper.
As usual all offers gratefully received.
Z900 Crankshaft
Re: Z900 Crankshaft
I have a crank not sure what from key way a little damaged, but you can have it if you want, I am just outside Wisbech.
Re: Z900 Crankshaft
you do know i've got 3 for sale don't you bill.................
Re: Z900 Crankshaft
Mine has gone to another home.
