For sale - refurbished Z900 (VM26 - Z1200) carbs
#1 PostAuthor: Ultim8pc » Sat Nov 20, 2021 3:32 pm
Kawasaki Z900 (Mikuni VM26) carburettors - refurbished by me.
These are ideal if you are looking for a set of correct carbs for your Z900 which have not been polished to death or had the original finish removed with vapor blasting.
They are in outstanding, original condition and have the all important bracing bar. I'd rate them at 9/10 condirion.
They've been completely stripped, ultrasonically cleaned, all internals checked, airways blown out, slide & float heights set. With actual fuel levels verified and checked for leaks.
Fitted with the following new items:
Petrol proof viton float bowl gaskets
Carb top gaskets
OEM bowl and carb top screws
Main jets o Bowl drain screws
O-rings
Choke plunger seats by Rob Megitt
Specifics:
Mikuni VM26S (Z1200)
Main Jet: 115
Pilot Jet: 17.5
Needle: 5DL31
Slide cut out: 1.5mm
£595
Re: For sale - refurbished Z900 (VM26 - Z1200) carbs
#2 PostAuthor: Bill P » Sat Nov 20, 2021 5:52 pm
Lovely job you've done there , Great price to.
#3 PostAuthor: Ultim8pc » Sun Nov 21, 2021 9:49 pm
Bill P wrote:Lovely job you've done there , Great price to.
Cheers Bill,
I'm all for keeping stuff as original as possible.
dave cullen
#4 PostAuthor: dave cullen » Sun Dec 26, 2021 5:40 pm
agree, I bought a refurbed set off Wired George ones a few years back, they cost around £350 without getting caught for import duty and Rob Meggit fitted them for me and set them all up, well worth it to get the bike running properly after storage issues.
Z900A4 Z1000A1
Return to “For Sale”
Users browsing this forum: SuffolkZ1r and 30 guests
