A friend of mine is swopping out a J swing arm for a modified one. He says he measured with the swing arm in situ, and the fitting dimension as 236mm..... Should it be 235mm???
Can anyone confirm please
Rob
Z1000J swing arm dimension
paid up member
- warren3200gt
Re: Z1000J swing arm dimension
Got a bare frame and swing arm in the workshop at the mo Rob. Can measure whatever you need later once I get there.
- warren3200gt
Didn't get chance today Rob, sorry. I will check tomoz.
- warren3200gt
I make it 236 as well Rob.
