998cc barrels
Spamwood999
998cc barrels
#1 PostAuthor: Spamwood999 » Wed Jan 05, 2022 5:38 pm
Hello. I need a set of J barrels for my project. I will be boring them out so a LITTLE damage is nothing to worry about.
They are going into an 1100 block with 1070 hi comp pistons Then squeezed into a Z650 frame.
Ta.
Re: 998cc barrels
#2 PostAuthor: warren3200gt » Wed Jan 05, 2022 8:29 pm
Might be able to help you out in a month or two. Doing the opposite putting 1100 top end on a 1000 bottom end so assuming all is OK the 1000 block will be superfluous to requirements.
By Brands Hatch.
Spamwood999
Re: 998cc barrels
#3 PostAuthor: Spamwood999 » Tue Jan 11, 2022 4:42 pm
Yes please.
I will have an 1100 top end if you are interested.
Near Margate.
Re: 998cc barrels
#4 PostAuthor: warren3200gt » Tue Jan 11, 2022 6:29 pm
OK, your name is on it. Barrels have a bit of surface rust but if your boring it it shouldn't be an issue. The whole bike was dismantled when I got it. I have pistons,rings and head also if you need them.
Cases are split at the moment cleaning them up. Awaiting gasket and seal sets from zp before I can rebuild it and check out if the 1100 conversion is good. Assuming all is good your name is on the 1000 set.
Spamwood999
Re: 998cc barrels
#5 PostAuthor: Spamwood999 » Thu Jan 13, 2022 4:30 pm
Great thanks. Just need the barrels. Boring them out to 1070.
gmc999@yahoo.co.uk
Ta.
