clutch side sprocket casing
jamfan
#1 PostAuthor: jamfan » Wed May 14, 2008 10:05 pm
Hi lads, My gear change shaft is sloppy in the outer casing. I have removed this to look at. Is there a bushing that can be replaced or is it the casing that wears. I'm not sure as I cant see one. (the thread has also gone in the clutch cable and will require helicoiling)
thanks for any help. :D
london calling
#2 PostAuthor: london calling » Thu May 15, 2008 5:14 am
Thread on the clutch cable :?: :?:
Which model Z is it ?
Jack
RALPHARAMA
#3 PostAuthor: RALPHARAMA » Thu May 15, 2008 6:54 am
If memory serves me right the shaft is supported by the aluminium casting. But there is no reason why this couldn't be carefully opened up and have a phosphor bronze bush fitted, though you would need it done by someone who is a reasonable engineer.
Ralph Ferrand
jamfan
#4 PostAuthor: jamfan » Thu May 15, 2008 9:46 pm
The thread on the housing where the cable enters the casing is stripped. It's my B2.
many thanks :D
