Z1000J Tank and side panels wanted
Hi, i am looking for a Z1000J Petrol tank and side panels, i dont mind a scruffy tank with some dents aslong as it holds fuel ! . Also looking for some Z1000J clocks. Anything considered. Thanks.
Re: Z1000J Tank and side panels wanted
Jerry does good quality reproduction ones. More sturdy than original ones.
Rob
Rob
If you get stuck I've got a solid GPz1100b tank.
It's the same shape as the J and fits on mine.
You'd need to get the extra GPz holes for fuel pump and return feed capped (they're both threaded but taped over in the photo) but it should be fairly straightforward.
H2B GPZ900R
Hi, yes i am very interested, how much are you looking for as a good one is very difficult to find.
Thanks, Neil.
Thanks, Neil.
Hi Neil,
Thinking maybe around £90 ?
I see you're about 90 mins away from me (in Sutton Coldfield).
I could send you some more pics tomorrow or didn't know whether you'd want to see the tank first?
Not sure how much postage would cost.
Cheers,
Rick
Cheers,
Rick
H2B GPZ900R
Hi Rick.
That sounds good to me, would you reckon on £30 for postage and packaging ?. How would you want payment , i am not in a major rush to get the tank, so at your leisure.
Once again many thanks, another item crossed off my "need to get " list . Cheers , Neil.
Great, I'll check out how much postage/courier will be (hopefully less than £30) and get back to you.
I think I've got a fuel level sensor which I now recall is actually one of the 2 spare holes, so only one should need blanking off.
I maybe have a couple of other small bits and pieces for a J too if interested. I'll check tomorrow.
H2B GPZ900R
Hi Rick,
Thanks much appreciated.
Neil
Neil
Hi Neil,
I've also got:
a fuel level sender unit with float etc.
an American 85mph speedo
GPz1100 oil cooler and engine take-off (but no hoses)
oil pressure sensor (which will fit the J take-off but not the GPz one with the oil cooler)
Let me know if you're interested in any of this and I'll work out the price and postage.
Cheers,
Rick
I've also got:
Cheers,
Rick
H2B GPZ900R
Hi Rick,
I would be interested in the fuel sender and the oil cooler aswell, thanks.
Neil
Neil
Hi all, How can i get in touch with "Jerry" regarding repro side panels ?. Thanks, Neil.
PM him as he is the fella in charge of the Z1OC.
Thankyou.
Users browsing this forum: Google [Bot] and 36 guests
