Z1000R Wiring
Skid Mark
Z1000R Wiring
#1 PostAuthor: Skid Mark » Wed Feb 09, 2022 8:55 pm
Hi all!
I'm tidying up the loom before the nesting season starts.
I have a Blue/orange wire cut clean. It's taped to two black wires which are on a triple connector, there are only two brass female connectors in the triple block. Looking at the diagram, I think the BL/O wire belongs in the connector. Problem is I can't make out any detail in the diagram. I think it is going into a Reserve Lighting unit, but I can't really make it out. If this is correct what is the unit and its function.
Thanks in advance.
P
scott
Junior Section leader
Re: Z1000R Wiring
#2 PostAuthor: scott » Thu Feb 10, 2022 11:47 am
I would also like to know a bit about this unit you mention too Mark. I have a brand new Z1000R USA wiring harness and it may need this unit attached unless i can find out exactly what it does and then bypass it.
Re: Z1000R Wiring
#3 PostAuthor: z1bman » Thu Feb 10, 2022 1:05 pm
The reserve lighting system is a safety device for the usa & when your headlight bulb fails it automatically switches over to the other fillerment. not fitted to european models
scott
Re: Z1000R Wiring
#4 PostAuthor: scott » Thu Feb 10, 2022 1:09 pm
Sounds relatively easy to bypass it, certainly seems achievable looking at the diagram.
Re: Z1000R Wiring
#5 PostAuthor: z1bman » Thu Feb 10, 2022 1:26 pm
to bypass the relay connect the blue & the blue/yellow wires together with the relay disconnected
scott
Re: Z1000R Wiring
#6 PostAuthor: scott » Thu Feb 10, 2022 1:36 pm
Thank you kindly for the info
Skid Mark
Re: Z1000R Wiring
#7 PostAuthor: Skid Mark » Thu Feb 10, 2022 3:38 pm
Thanks,
I might be back for further guidance.
P
