I received a very clean set of gold Showa shocks for the ELR. Thanks Uli!
Before I put these on proper, I want to check if they are in need of attention.
There is a small dial in the ali housing between the bottom bush and the stauntion. I removed the spring from one shock and checked the compression and rebound at different dial positions. The dial only seems to dampen rebound. So, I think I have compression preload and rebound damping only, is this correct for these shocks?
As always, thanks in advance.
P
Showa shocks
