In line filter
In line filter
Aye up guys, the fuel lines on my z1000a1, duel feed, the internal bore is 6mm, if I put an in line filter into each line, which are sold as 6mm, would they reduce the flow to effect the performance, as the inlet and outlet is about 4mm, just asking.
Re: In line filter
DavidZ1R wrote:Aye up guys, the fuel lines on my z1000a1, duel feed, the internal bore is 6mm, if I put an in line filter into each line, which are sold as 6mm, would they reduce the flow to effect the performance, as the inlet and outlet is about 4mm, just asking.
Im pretty sure you don't ride it fast enough
And as an aside it makes no difference on any of mine
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
- warren3200gt
Re: In line filter
Just remember to get the flow direction right.
Re: In line filter
both of the above. No fuelling issues on my 1105 Z1 with inline filters
Re: In line filter
KeithZ1R wrote:DavidZ1R wrote:Aye up guys, the fuel lines on my z1000a1, duel feed, the internal bore is 6mm, if I put an in line filter into each line, which are sold as 6mm, would they reduce the flow to effect the performance, as the inlet and outlet is about 4mm, just asking.
Im pretty sure you don't ride it fast enough![]()
Price of fuel, is it any wonder Keith, classics are meant to be enjoyed, not ridden fast, those days are long gone, in more ways than one.
Re: In line filter
warren3200gt wrote:Just remember to get the flow direction right.
Hi Warren, I got some fuel pipe from someone you recommend a good while back, who was it? Someone darn sarf somewhere, happy with the last lot.
- warren3200gt
Re: In line filter
That'll be afs David.
https://www.advancedfluidsolutions.co.uk/
