Looking for a set of coils to use on the MK2 style transistorised ignition system.
Am I right in thinking I need 1.5 Ohm coils.
Does anybody know an aftermarket supplier of said coils with a 90mm mounting pitch?
Gus.
Coil confusion
Coil confusion
"Set the GRINDER on it"
Re: Coil confusion
Hi Gus
have a look at these:
https://www.z-power.co.uk/z1000a3a4b3b4 ... 000-models
just ask if they will fit your bike.
Re: Coil confusion
Gus I ditched the Ballast resistor and put green3 ohm Dyna's on mine and it has run faultlessly, so there is no good reason not to use the chinese Dyna copies
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
Re: Coil confusion
Try Grumpy 1260 for the coils, he tends to have them in stock.
07774924067.
Rob
07774924067.
Rob
Re: Coil confusion
wemoto.com sell them also.
check whether they're 90mm or 100mm centres.
Re: Coil confusion
Thanks for the replies and leads guys.
After thinking last night my next question was going to be could I ditch the resistor.
Cheers again.
Gus
Cheers again.
Gus
