Rough running Z1 900
Rpp999
#1 PostAuthor: Rpp999 » Fri Apr 01, 2022 4:33 pm
Hi, my Z1 is running really rough. Just had the petrol tank lined, carbs cleaned and new plugs fitted. On starting it pops and farts running on 3 and occasionally 4. Where would be a good place to start. TIA.
Re: Rough running Z1 900
#2 PostAuthor: warren3200gt » Fri Apr 01, 2022 6:55 pm
If its running at all the tank/tap must be supplying fuel so carbs, either bad clean job or need setting up properly.
Float height, bench sync, vac sync, mixture.
Rpp999
#3 PostAuthor: Rpp999 » Fri Apr 01, 2022 7:28 pm
Ok, thank you for your reply. I will try and get the carbs set up and balanced.
Rpp999
#4 PostAuthor: Rpp999 » Fri Apr 01, 2022 7:30 pm
You wouldn’t know a local reliable person by any chance ?
#5 PostAuthor: ADRIAN H » Fri Apr 01, 2022 7:40 pm
Rpp999 wrote:You wouldn’t know a local reliable person by any chance ?
you may want to contact Dave Ennis @ Buzzworkz, Hampton, London - link to facebook -
https://www.facebook.com/BuzzWorkz/
an article on his work link - https://www.visordown.com/feature/road- ... lding-guru
#6 PostAuthor: warren3200gt » Fri Apr 01, 2022 7:50 pm
If your in Bexleyheath, I'm just by Bluewater. Don't profess to be an expert but built and re commissioned plenty of Z"s
I agree Dave Ennis is a good commercial bet.
Rpp999
#7 PostAuthor: Rpp999 » Sat Apr 02, 2022 7:00 am
Thank you for taking the time to reply. Will certainly make contact.
#8 PostAuthor: warren3200gt » Sat Apr 02, 2022 7:46 am
Replied.
Rpp999
#9 PostAuthor: Rpp999 » Sun Apr 03, 2022 5:58 pm
All sorted now. Thanks to an extremely nice and helpful club member. You are a legend.
#10 PostAuthor: warren3200gt » Sun Apr 03, 2022 7:31 pm
Not a problem Ray, no one on here likes to hear of a poorly Z and not try to help. :up
#11 PostAuthor: ADRIAN H » Mon Apr 04, 2022 5:40 pm
warren3200gt wrote:Not a problem Ray, no one on here likes to hear of a poorly Z and not try to help. :up
Nice one. :D
Andrew_s
#12 PostAuthor: Andrew_s » Wed Apr 06, 2022 12:00 pm
Nice one. :D
:up Power of the forum!
Current Bikes:
2023 R1250 GSA
