Hi All,
I have for sale a surplus to requirements 4 bolt front wheel which is good for a number of models including Z900, Z1000 etc.
I restored this wheel a while ago with the intention of fitting it to my A1 but another wheel came along with a more appropriate date code so this is now surplus to requirements.
Includes-
1, Newly re chromed 1.85x19 Takasago rim date coded 6B, 305. It was show chromed by Prestige in Mexborough and they did a great job without destroying the Takasago stamp.
2, Restored hub with good original bearings, cleaned and re greased with new oil seal fitted. The hub is in great shape and hasn’t been over polished or lacquered and all threads are good.
3, Brand new butted spoke set fitted along with rim tape.
The rim did have a little corrosion on the inside surface in places as most of these original rims do but it doesn’t affect its performance.
The wheel will require balancing when a tyre has been fitted.
My aim is to try and get the money back that it cost me to get it to this condition including the cost of the original wheel.
£255 plus Delivery.
PM if interested.
Cheers.
Z900/Z1000 OEM Restored Front Wheel
