Most of these parts are damaged and corroded but not beyond repair, so rather than hanging onto them, they may be useful to someone.
Rear light and bracket.
Rear mudguard - the plastic one under the battery box.
Front mudguard
Chain guard ( plastic)
Battery box and battery tray
Front and rear foot rests
Head lamp unit and fork shrouds
Front wheel with discs, spindle and speedo drive
Rear wheel with disc and sprocket
Front forks (pitted), yokes and brake callipers
Metmachex swinging arm (steel) with adjusters, frame spindle, wheel spindle, calliper and torque arm
Marzocchi rear shocks
Rear brake lever, master cylinder, rod and return spring
Gear change lever
Clocks, gauges, warning lights and plastic console (broken) on bracket with wiring, speedo cable with indicator cancelling gizmo, Stanley self-cancelling unit, tacho cable and drive unit.
Horn
Grab handle - the one that bolts onto the top of the rear shock near side.
Petrol tank (battered) with filler cap, petrol tap and sender.
I've got photos of all these items so you can see the condition of them but there's too many to put on here. Just ask if you're interested in anything above and I'll send the pictures to you, then make me an offer.
Z1R Parts for sale
- The Living Zed
- Regular Poster
- warren3200gt
Re: Z1R Parts for sale
Need prices or administration will remove
International Rep
International Rep
