1973 Z1 for sale
gtookey
1973 Z1 for sale
#1 PostAuthor: gtookey » Mon Jun 20, 2022 4:26 pm
Hi all,
It's time to sell my Z1, a March 1973 Manufactured (US) bike imported to UK at the end of 2007
Restored to high standard in 2008-9 including engine, frame, panels except for tank which remains original.
Tank has some chips and a scratches as shown in pictures, but presents well
Rims have some light corrosion
Chain Oiler present inc engine components (plastic oil reservoir)
Matching numbers 102xx and 103xx - 128 apart
Registered as an historic vehicle
Pictures should be viewed as they form part of the offer
Invoices for engine overhaul present
Box of spares will also go with the bike ( various used but serviceable in the main, motor components)
Exhaust is original, it has a small hole in top left silencer, but this has not worsened in 6 years of ownership
it has covered 5000 miles in 15 years
It is correct for 1973 inc
* Early Fuel Tank with short emblems
* Exhaust is stamped Z1900 / Z2 750 ( i.e. not late 76 stamping)
* Warning light console, instruments correct for 73 Z1
* Early carbs with large alloy hex nut float bowl drains
* Early mirrors without reinforcing joint at shoulders
* Rear brake hub without wear indicator
* Black finished fuel tap
* Early throttle body with friction screw
* Early headlamp with bowl stay
* Early 751 lock set ( only one key)
* early transmission cover without gear position indicator
* Early seat with 2 part foam
* Early chain adjusters with M8 adjuster bolts
* Early horn assembly with screws retaining outer rim.
all key components (nuts, rim brake torque arm carry date stamp
rebuilt with genuine Kawasaki or OEM parts, not pattern parts.
Photographs of rebuild available
Registration document shows 1 former keeper.
I am looking for offers over £18000
A buyer will also have first offer of a boxed, unused genuine Kawasaki exhaust system although this is for a later Z1A on, model.Part No. 18001-227- 230. I will sell this separately later at £1950.
PM if interested.
Bike located in London Docklands E16
Regards
Glenn
baz
Re: 1973 Z1 for sale
#2 PostAuthor: baz » Mon Jun 20, 2022 5:24 pm
pics are a bit naff !
gtookey
#3 PostAuthor: gtookey » Mon Jun 20, 2022 6:10 pm
That's an iPhone for you! Trying to capture the imperfections.
badgb21
#4 PostAuthor: badgb21 » Mon Jun 20, 2022 7:55 pm
gtookey wrote:That's an iPhone for you! Trying to capture the imperfections.
I think you might need a few overall pics of the bike as well :?? Iphone should do it.
nick sanderson
#5 PostAuthor: nick sanderson » Mon Jun 20, 2022 8:30 pm
That frame is 15 off mine
gtookey
#6 PostAuthor: gtookey » Tue Jun 21, 2022 7:56 am
Sorry, I thought I'd posted bike pic
gtookey
#7 PostAuthor: gtookey » Tue Jun 21, 2022 7:57 am
..another
wilsonsjw11
#8 PostAuthor: wilsonsjw11 » Tue Jun 21, 2022 12:40 pm
Glenn,
Would you mind stating what work was carried out during the engine rebuild.
Regards
Steve
gtookey
#9 PostAuthor: gtookey » Tue Jun 21, 2022 6:23 pm
Hi Steve
Engine full strip by Mike Honniset using all genuine Kawasaki parts
New Cam chain front and rear cam chain idler assemblies, cam cover end plugs, valve stem oil seals, oil pressure switch
New valve guides and re-cut valve seats
Bores Honed
New piston rings
New clutch friction plate set
530 Gauge chain and sprocket set
2 pack satin finish paint, repolished castings and original fasteners re-plated and re-used.
Carbs - full strip, bodies ultrasound cleaned
New keyster kits fitted inc jets, valves gaskets
Genuine Kawasaki air filter element
New inlet rubbers
Chassis / body
Tank, side panels and tail retained in original paint
Original seat pan and early 2 part foam retained, replica cover fitted
Genuine new Kawasaki footrests front and rear
Complete Genuine Kawasaki toolkit with early type padded pouch
Wheels dismantled rebuilt
Forks stripped hard chromed
Yokes, headlamp bowl etc painted to original factory finish
New tapered headrace set
Original front and rear mudguards
Full brake overhaul
Electrics
OEM TEK 3 loom new
DYNA S Coils with original US spec non branded black plastic plug caps
Original indicators with genuine Stanley lenses
Regards
Glenn
#10 PostAuthor: Philippe » Wed Jun 22, 2022 3:50 am
Hi Glenn
it's a stunning bike!
With all that work done and money spent, the new owner will have a magnificent bike.
Great job!
I hope you can sell it for a correct price because it's worth it.
Mikekilbride
#11 PostAuthor: Mikekilbride » Thu Mar 09, 2023 5:10 pm
I agree with Philippe
:luv This old GIT keeping the old "kawi's" rolling 5 x Z1's. 3 x 72' H2's. 2 x 73' H2's. 2 x 74 H1's. 1 x 71 H1. 1 x W1 and finally 2 x 69' A7SS :luv
#12 PostAuthor: chrisNI » Thu Mar 09, 2023 9:17 pm
Nice bike glws :D
#13 PostAuthor: paul doran » Sun Mar 12, 2023 8:31 pm
Nice 73 a proper bike
I am sure it will sell easily
Andy M
#14 PostAuthor: Andy M » Sun Mar 12, 2023 8:39 pm
Well it went up for sale June last year :jake
Andrew_s
#15 PostAuthor: Andrew_s » Tue Mar 14, 2023 6:42 pm
Andy M wrote:Well it went up for sale June last year :jake
Think it might have gone by now then......... :biggrin
Current Bikes:
2023 R1250 GSA
Return to “For Sale”
