First techy post since I registered.
For the second time in about four years the fuel tap has started leaking. It is a vacuum operated, ON/PRIME/RESERVE type. It is not leaking down the fuel hose, but leaking around the tap handle.
I guess that the rubber disc with the five holes is the culprit again. Last time I used a reseal kit from Z-Power. Is there something extra I can do when I re-assemble the tap, or is it just a fact of life that when the tap sits in the same position for a few years, it will develop a leak.
Fuel tap leak, Z1100A
'Dying a'int much of a living, boy'
Outlaw Josey Wales
Member No. 555
Outlaw Josey Wales
Member No. 555
- paul doran
