Clocks mounting bracket foam
PhilMill63
#1 PostAuthor: PhilMill63 » Thu Oct 06, 2022 4:50 pm
Is it possible to buy the foam bits that go under the speedo and tacho on the mounting bracket? I have a broken bracket and my options are buy and copy bracket with the foam on it or buy a used one a re-paint, for that I need new foam.
Thanks, Phil
'76 Z900A4, '76 Suzuki GT750, '83 RD350 Hybrid and too many projects!
Re: Clocks mounting bracket foam
#2 PostAuthor: deka » Fri Oct 07, 2022 9:02 am
hi phil
I am assuming 900 you can buy a complete clock mount kit from zpower https://www.z-power.co.uk/meter-bracket-z1ab
PhilMill63
#3 PostAuthor: PhilMill63 » Sun Oct 09, 2022 7:14 am
deka wrote:hi phil
Opps, should have said 900. So I guess best bet is copy bracket then. Thanks.
#4 PostAuthor: chrisu » Sun Oct 09, 2022 1:49 pm
or just but a sheet of foam off ebay and cut to fit.
#5 PostAuthor: r3sc » Sun Oct 09, 2022 4:12 pm
I recently bought a piece of this in 5mm thickness and it works great!
https://www.ebay.co.uk/itm/144647390007 ... media=COPY
PhilMill63
#6 PostAuthor: PhilMill63 » Mon Oct 10, 2022 5:53 pm
r3sc wrote:I recently bought a piece of this in 5mm thickness and it works great!
That looks ideal, thanks.
