z1000 J/K/M carbs PRICE REDUCTION
gray
#1 PostAuthor: gray » Tue Oct 18, 2022 5:09 pm
About a year ago I bought a z1000M engine and carbs from a fellow Z1OC member for my special frame. Unfortunately the engine wouldn't fit so is now sold. I had stripped the carbs , ultrasonically cleaned them and rebuilt them to J spec. New float bowl gaskets etc. The linkages and choke now work ( choke linkage rod was bent) .
Pilot jets are the same between J and M, but main jets are different ( J has 127.5) This is of course for a standard J running a standard exhaust. I thought that most Js would be running a 4 into 1 so upjetted a little with 130s.
Anti tamper bungs were drilled out and air screws set to standard J ( 1 1/4 turns out)
Ready to fit and then you can sett idle speed/ balance etc
gray
gray
Re: z1000 J/K/M carbs
#2 PostAuthor: gray » Tue Oct 18, 2022 5:10 pm
oops forgot the price £180 + postage.
gray
gray
Re: z1000 J/K/M carbs PRICE REDUCTION
#3 PostAuthor: gray » Tue Oct 25, 2022 7:08 pm
OK I'm keen to move these on - so £150 inc postage is my revised price
gray
#4 PostAuthor: Ultim8pc » Fri Oct 28, 2022 10:41 am
PM for you.
gray
Re: z1000 J/K/M carbs now sold
#5 PostAuthor: gray » Mon Nov 21, 2022 7:41 pm
now sold
gray
Return to “For Sale”
