Starter motor test
shaggy
Starter motor test
#1 PostAuthor: shaggy » Mon Jan 02, 2023 3:02 pm
I have a starter motor I am using on an engine rebuild so need to check it works before I bolt it on.
So probably a dumb question but how do I do this off the bike :glare
Peteypops23
Re: Starter motor test
#2 PostAuthor: Peteypops23 » Mon Jan 02, 2023 3:51 pm
Arite Bud.... do you just want to make sure it spins up?
If so, connect earth from battery to body of starter then, holding the starter coz it might jump, attach a lead to positive battery terminal and then touch other end to cable terminal bolt on starter. It should spin up...obviously this won't tell you if it will work under load....no doubt someone else may have that info.
weaver
#3 PostAuthor: weaver » Tue Jan 03, 2023 9:43 am
as above probably worth opening it up and checking the brushes etc
KevH
#4 PostAuthor: KevH » Sat Jan 07, 2023 8:49 pm
Only last month, I had a starter that was seized solid after 25 years of standing unused. I held the gear in a vice and gently worked it back and forth and it works perfectly well now. It surprising how durable they are. The only real way to test under load is on the engine.
