WISECO K1136 74MM PISTON KIT, brand new boxed
Brand new WISECO gpz1100 1981/82 piston kit, 74mm, in the original box, part number K1136, 4256PS-4, 2913XC, i have also got 2 engines, a spare set of crank cases, a brand new un painted HARRIS MAGNUM 2 full fairing with screen, 07881740870 cheers john
Re: WISECO K1136 74MM PISTON KIT, brand new boxed
Prices and pictures are required. Thanks.
i,ll get out in the shed and take some pics in daylight tommorow, the piston kit is £ 400, ive got a head and base gasket as well, the engines are beeing sold together £1000, and £400 for the magnum fairing, its all going on ebay on sunday evening
I take it the piston kit is 10.25:1 CR
i cant find away of loading the pictures up on this site ??
im not sure on the comp ratio of the pistons, you may need to cross ref the part number, cheers john
Pictures- click post a reply. Under the text box are 2 tabss
OPTIONS / ATTACHMENTS
click on ATTACHMENTS
Dialog box opens click on box saying ADD FILES.
Find pictures on your computer. Hit add button wait till you get a Green tick picture has been added.
