GPz1100B2 Fork damper tool.
BAFF1960
#1 PostAuthor: BAFF1960 » Sun Feb 12, 2023 10:49 am
Hi.
After recommissioning after a decade lay up and some use late last year my B2 has blown a fork seal. Have original new item[s]to install but need the info on the damper rod removal tool. I can make one easily but need the dimensions for it. Can anyone supply me with the info?
Regards Alan
MikeP
Re: GPz1100B2 Fork damper tool.
#2 PostAuthor: MikeP » Sun Feb 12, 2023 11:16 am
#3 PostAuthor: Al » Sun Feb 12, 2023 11:47 am
22 and a bit inches in length.
21 and a bit mm across flats.
If you have NOS but older seals you might do well to replace with the more recent version since the originals were superseeded and i believe better designed subsequently!!
BAFF1960
#4 PostAuthor: BAFF1960 » Sun Feb 12, 2023 1:45 pm
Hi.
Thanks for the info. I have new [ expensive ] genuine Kawasaki seals. Wouldn't use NOS seals from experience as they don't age well when not stored correctly.
Alan.
