GPz1100A1 - Assorted Spares
Ragster
#1 PostAuthor: Ragster » Fri Feb 17, 2023 3:12 pm
Hi, my build is finished and I have some spares that I'm no longer needing or going to use:-
Standard barrels and pistons, standard bore, approx. 14,000miles on them, £250 Plus P&P
Ignition Coils, Leads and Plug Caps, £30 Plus P&P
Reg/Rectifier, £25 Plus P&P
Standard Head and Base Gaskets, Valve Oil Seals, £20 Plus P&P
Set of Inlet Rubbers, £30 Plus P&P
Hydraulic Clutch Conversion Plate, £50 Plus P&P
Pattern Rear Light, £10 Plus P&P
Slotted Camshaft Sprockets, £40 Plus P&P
Thanks for looking,
DJ
Robw
Re: GPz1100A1 - Assorted Spares
#2 PostAuthor: Robw » Fri Feb 17, 2023 5:46 pm
Interested in the 74mm barrels, just need to check on sizes I need.
Rob
Robw
#3 PostAuthor: Robw » Fri Feb 17, 2023 6:25 pm
Hi, will be interested in the rebored barrels, what condition are the bores in as I plan to use them as 1170 ones, should mine get damaged.
Cheers Rob
Ragster
#4 PostAuthor: Ragster » Fri Feb 17, 2023 7:18 pm
Hi, I would say the bores are good, no scoring or rust etc. They've been kept oiled but would probably benefit from a light hone before use.
Thanks,
DJ
Robw
#5 PostAuthor: Robw » Fri Feb 17, 2023 9:34 pm
I will send you a pm.
Rob
Ragster
#6 PostAuthor: Ragster » Sat Feb 18, 2023 7:58 am
Ok, thanks
kawasaki_man
#7 PostAuthor: kawasaki_man » Sat Feb 18, 2023 5:32 pm
Hi DJ,
I will take the PMC billet engine mounts.
Pm sent
Regards
Peter
Ragster
#8 PostAuthor: Ragster » Sat Feb 18, 2023 5:45 pm
Hi, PM replied to.
DJ
Zoso
#9 PostAuthor: Zoso » Wed Mar 08, 2023 8:00 pm
Hi
Have you still got the camshafts and camshaft sprockets for sale please ?
cheers
Ragster
#10 PostAuthor: Ragster » Thu Mar 09, 2023 6:36 am
Hi,
I have the re-ground camshafts, standard and slotted sprockets still available.
Thanks for looking,
DJ
Zoso
#11 PostAuthor: Zoso » Thu Mar 09, 2023 4:19 pm
Thanks. I'll send you a PM.
Return to “For Sale”
Users browsing this forum: No registered users and 8 guests
