Z400b2
DavidZ1R
Z400b2
#1 PostAuthor: DavidZ1R » Sun Mar 12, 2023 2:47 pm
Aye up guys, looking for advice on my latest project, engine rebuilt, new rings hone etc, started first time after rebuild. However, revs hang, won't idle at 1000 to 1200 rpm, left carb shows higher pull than right carb, twice as much, checked for air leaks, all seem good, had carbs off and checked, good blue flame on the gunsun , starts ok. When hot, but the starts to climb the revs up to 2300 rpm And hangs, if I hold the throttle tight down it does drop revs but then climbs back. I'm baffled of Bolton. Cables set as per spec. Any thoughts.
Re: Z400b2
#2 PostAuthor: chrisNI » Sun Mar 12, 2023 10:21 pm
Are they CV carbs?
DavidZ1R
Re: Z400b2
#3 PostAuthor: DavidZ1R » Mon Mar 13, 2023 9:32 am
Yes, I am mystified
Users browsing this forum: Bing [Bot] and 71 guests
