Piper 4-1 to fit A4
zapo
Piper 4-1 to fit A4
#1 PostAuthor: zapo » Fri Mar 24, 2023 3:41 pm
Does anybody have an original Piper 4-1 that they would like to sell, with or without baffle.
An immaculate NOS one would be great but that's probably a bit of a pipe dream. Pun intended :D
Failing that, a solid presentable chrome one or a solid one in need of rechroming.
I see Zed people.
Re: Piper 4-1 to fit A4
#2 PostAuthor: warren3200gt » Fri Mar 24, 2023 3:46 pm
Are you sure you meant Piper and not Alfa? The chances of finding a piper are sparkley rocking horse poo with rainbow sprinkles.
Delkevic is the closest your likely to get now.
They are well made and stainless at a reasonable price.
zapo
#3 PostAuthor: zapo » Fri Mar 24, 2023 4:10 pm
Yes, Piper.
Long, upswept straight silencer exiting on the right.
I know that they are rocking horse sh!t but no harm to ask.
The delkevic don't sweep up enough for me.
I see Zed people.
#4 PostAuthor: chrisNI » Fri Mar 24, 2023 4:19 pm
zapo wrote:Yes, Piper.
The Delkevic is stainless iso it could be cut re-angled and welded and polished so you wouldn't see the join if you have a handy welder.
#5 PostAuthor: warren3200gt » Fri Mar 24, 2023 4:27 pm
I had a piper on a 650 way back when and when I built my retro custom 650 only using period parts I ended up having to make a piper replica as they are not around. They were fairly scarce 40 years ago compared to Alfa, Lazer etc.
If I were to do it again I would use delkevic headers and build back from there.
DeadZedDave
#6 PostAuthor: DeadZedDave » Sat Mar 25, 2023 10:54 am
Zapo, just checking the picture shows the Piper exhaust you’re looking for ? Not much like a Delkevik to my eye ! The front down pipes / headers tuck in really tight to the frame and enter the collector from a splayed out angle.. Early S+S is closer or some early Yoshi but I think if you want one like in the picture the it has to be Piper ? N.B. Very early Pipers had the 2.5 tail pipe made in 3 straight sections welded together to get the angle …in the advert it’s the later “bent type” which looks a bit smoother. Somebody somewhere will have one !
King of Kings
#7 PostAuthor: King of Kings » Sat Mar 25, 2023 12:57 pm
They where £67 in chrome or £57 painted black, had a brand new one still boxed in me mam’s loft until recently, then me scummy poxy sibling chucked it in a skip :shock:
zapo
#8 PostAuthor: zapo » Sat Mar 25, 2023 1:08 pm
DeadZedDave wrote:Zapo, just checking the picture shows the Piper exhaust you’re looking for ? Not much like a Delkevik to my eye ! The front down pipes / headers tuck in really tight to the frame and enter the collector from a splayed out angle.. Early S+S is closer or some early Yoshi but I think if you want one like in the picture the it has to be Piper ? N.B. Very early Pipers had the 2.5 tail pipe made in 3 straight sections welded together to get the angle …in the advert it’s the later “bent type” which looks a bit smoother. Somebody somewhere will have one !
Yep, that's what I am after.
I see Zed people.
zapo
#9 PostAuthor: zapo » Sat Mar 25, 2023 1:11 pm
King of Kings wrote:They where £67 in chrome or £57 painted black, had a brand new one still boxed in me mam’s loft until recently, then me scummy poxy sibling chucked it in a skip :shock:
Oh dear :evil:
Yes, I brought two back in the day, £75 each ......should have made it three :D
I see Zed people.
#10 PostAuthor: chrisNI » Sat Mar 25, 2023 5:17 pm
The Delkevic headers are more like a Kerker but I always thought the thin drainpipe silencer was the characteristic feature of a Piper rather than header angles.
#11 PostAuthor: Al » Sat Mar 25, 2023 7:22 pm
#12 PostAuthor: paul doran » Sat Mar 25, 2023 8:53 pm
I have a used one that has about four inches cut off it
#13 PostAuthor: chrisNI » Sun Mar 26, 2023 10:29 am
Good thought Al I’d forgotten Dave did a Piper type one :shock:
zapo
#14 PostAuthor: zapo » Sun Mar 26, 2023 2:15 pm
paul doran wrote:I have a used one that has about four inches cut off it
Thanks but I want one at the full original length.
I see Zed people.
neilbarrett
#15 PostAuthor: neilbarrett » Sun Mar 26, 2023 4:17 pm
I'd get a new one made in stainless
