HEL oil cooler kit for Z1000J/R type motor (may fit other later models too).
I bought this from the NEC show in 2017 direct from HEL when they were developing and considering marketing this kit. Don’t think they ever put it into production though (not sure why).
Consists of a 13-row black radiator, black pipes, all fittings, oil take off which retains the original oil pressure switch under the carbs.
Hardly used and in like new condition.
£150 or sensible offer. Can be collected from East Kent or posted at extra cost.
Hoses can be routed in several ways. I wanted it fitted with hoses exiting from top of the radiator but will work either way. Some more pics can be seen here.
viewtopic.php?f=4&t=43478&start=15
H2B GPZ900R
- warren3200gt
Re: HEL oil cooler kit for Z1000J/R type motor
Hi Rick, I could be your man for that. Pm will be sent shortly!
I'm a couple miles from Bluewater
Yes please if Warren doesn't want it.
Gus
Gus
"Set the GRINDER on it"
Gus wrote:Yes please if Warren doesn't want it.
Gus
OK, you've got second shout if Warren doesn't want it
H2B GPZ900R
- warren3200gt
Thanks Rick, good to meet up
