Z900A4 Brake pad fit in the mount
Stagman
#1 PostAuthor: Stagman » Fri Jul 14, 2023 9:56 am
Guys,
The method of brake pad location in the caliper mounting bracket is something i havent worked with for a long time so im not sure how snug the pad should be in the correspondingly shaped hole?
Is it a nice sliding fit in the hole or should it be fairly tight please?
I'm referring to the pad against which the piston pushes for clarity.
Thanks in advance
Regards
Mark
Stagman
Re: Z900A4 Brake pad fit in the mount
#2 PostAuthor: Stagman » Fri Jul 14, 2023 7:13 pm
Have decided a nice sliding fit is the way forward having out some new EBC pads in. My old pads were as tight as......
