gpz750 turbo engine
j.b
gpz750 turbo engine
#1 PostAuthor: j.b » Sun Jul 16, 2023 8:16 am
Gpz750 turbo engine for sale. It’s been in dry storage for many years, turns over with good compression, no stud, thread, or fin damage. Very clean and original looking inside the cam cover, will need a full cosmetic restoration and I’d also recommend an internal check with replacement cam chain, valve stem seals and piston rings, etc. it’s missing the ignition pick-ups but these are the same part as fitted on the standard gpz750 so easily available and I do have the starter motor and cover to go with the engine. Collection only from near Whitchurch, Shropshire.£700
Return to “For Sale”
Users browsing this forum: Google [Bot] and 36 guests
