Evening all
Does anyone know if it's possible to replace the throttle cable on a GPZ1100 Unitrack without removing the injectors ? I've spent too many hours wrestling to get the throttle bodies fitted into the airbox only to discover the throttle cable is badly frayed - not looking forward to having to remove them and repeat. Any suggestions will be most welcome.
thanks
GPZ1100 A1 Throttle Cable Replacement
Re: GPZ1100 A1 Throttle Cable Replacement
bit fiddly but you should be able to do it in situ...
paid up member
It is indeed fiddly. In the end I just took the throttle bodies back off.
