Z1000 A1 A2 Z1R head wanted
#1 PostAuthor: chrisNI » Tue Sep 12, 2023 8:45 am
Z1000 A1 A2 Z1R head wanted in reasonable shape for a local guy here who bought a bike and the head’s a real mess. Anyone got anything they might part with? PM me thanks
rpeters
Bristol's "H" Hoarder
Re: Z1000 A1 A2 Z1R head wanted
#2 PostAuthor: rpeters » Tue Sep 12, 2023 10:58 am
i have a Z1R head complte that has been stripped and blasted ready for paint and rebuild. I doubt it would be cheap though, what wrong with your mates existing head?
paid up member
#3 PostAuthor: chrisNI » Tue Sep 12, 2023 1:09 pm
rpeters wrote:i have a Z1R head complte that has been stripped and blasted ready for paint and rebuild. I doubt it would be cheap though, what wrong with your mates existing head?
More what's not wrong with it. We're trying to help him sort it at reasonable cost, his head would need about £800 spent to fix it but even then it's been badly ported which can't be undone and fins haven't been well repaired.
Big Fluff
#4 PostAuthor: Big Fluff » Thu Sep 14, 2023 5:13 pm
Chris. John Browse has bloody loads of heads. I only live down the road so if you want me to go over and eyeball one for you, no problem just PM me with your exact requirements.
#5 PostAuthor: chrisNI » Fri Sep 15, 2023 2:22 am
Big Fluff wrote:Chris. John Browse has bloody loads of heads. I only live down the road so if you want me to go over and eyeball one for you, no problem just PM me with your exact requirements.
Thanks Will might be worth a try
James
#6 PostAuthor: James » Fri Dec 22, 2023 5:02 pm
I have a head i got with a load of parts for a z1000a2 missing cam caps but apart from that it looks ok.
neilbarrett
#7 PostAuthor: neilbarrett » Sat Dec 23, 2023 1:00 pm
Try d&k .most of the heads you come across now are going to need work
#8 PostAuthor: chrisNI » Sat Dec 23, 2023 9:23 pm
Thanks for replies. Eventually went with getting Buzzard to comprehensively redo the chap’s original head, it needed a lot of work and wasn’t a cheap option but it’s a good job now and a known quantity, and ready to bolt on as opposed to spending nearly as much on a second hand head with no valves, unseen, and from an unknown origin … good heads these days are relatively scarce so most of what’s available is stuff that in days gone by would have been regarded as uneconomic to repair.
#9 PostAuthor: chrisNI » Sat Dec 23, 2023 9:23 pm
James wrote:I have a head i got with a load of parts for a z1000a2 missing cam caps but apart from that it looks ok.
Did you buy that A2 down in Mayobridge?
James
#10 PostAuthor: James » Sun Dec 24, 2023 11:47 am
Yes.
Stugill
#11 PostAuthor: Stugill » Sun Dec 24, 2023 12:26 pm
Good shout getting Buzzard to sort it, you know it's sound.
Stu
#12 PostAuthor: chrisNI » Tue Dec 26, 2023 1:10 am
James wrote:Yes.
Looked like a reasonable buy good luck with it.
James
#13 PostAuthor: James » Tue Dec 26, 2023 6:43 pm
Thanks.needs a bit of tlc but its well worth getting it sorted.
