Interchangeability of tanks and panels.
Big John
#1 PostAuthor: Big John » Thu May 29, 2008 4:23 pm
It turns out that the last Zed I purchased was a B3 and not a B2. As it is fitted with a MK2 engine I was wondering wether the MK2 tank, sidepanels and tailpiece are interchangeable. I'm sure I read somewhere that the Z900 through to J series body work was interchangeable. Can anyone advise as I thought it might look good with MK2 bodywork?
Dark Skies
Re: Interchangeability of tanks and panels.
#2 PostAuthor: Dark Skies » Thu May 29, 2008 5:31 pm
Big John wrote:It turns out that the last Zed I purchased was a B3 and not a B2. As it is fitted with a MK2 engine I was wondering wether the MK2 tank, sidepanels and tailpiece are interchangeable. I'm sure I read somewhere that the Z900 through to J series body work was interchangeable. Can anyone advise as I thought it might look good with MK2 bodywork?
If you give me a part number I can look it up on Zedder if you want.
KZ1000-M1 CSR
Iain marshall
#3 PostAuthor: Iain marshall » Thu May 29, 2008 5:51 pm
John sounds like an B3 you've got as it had a MK2 type engine, as did the B4.The Mk2 tank should fit ok,you would need the mounting plate off a Mk2 frame for the tail(or make your own)the side panels fitt but cant remember if i had to mod the lower mounts.
Big John
#4 PostAuthor: Big John » Thu May 29, 2008 7:12 pm
Guy, not sure of part numbers.
Iain,looking at a MK2 seat on ebay the seat fittings look diffferent to the A and B's
