Best re-lining prducts for my tank
Darth 1
#1 PostAuthor: Darth 1 » Wed Dec 06, 2023 6:24 pm
Hello folks was wondering if anybody can help i need to reline the inside of my petrol tank and wondering whats the best product to use , i have got all the rust out and old liner and its got wd40 and oil sealed just now ready for relining so any help would be great :D
Re: Best re-lining prducts for my tank
#2 PostAuthor: warren3200gt » Wed Dec 06, 2023 7:27 pm
You'll need to clean out the wd40 or the liner won't stick to the metal. I use POR 15 liner.
#3 PostAuthor: ADRIAN H » Fri Dec 08, 2023 1:41 pm
POR 15 is the most robust liner and is resistant to ethanol. It comes with a degreaser and metal cleaner. It can also be very tricky to get right.
Are you sure you need a liner ?
It is also difficult to remove POR15 without damaging your paint work.
Link to kit from Frosts
https://www.frost.co.uk/por15-motorcycl ... gIAyPD_BwE
Stugill
#4 PostAuthor: Stugill » Fri Dec 08, 2023 1:48 pm
I lined my tank a few years ago and it still seems in perfect shape.
I put this topic on as a basic aide memoire.
Good luck.
Stu
viewtopic.php?f=32&t=47199
Speedie
#5 PostAuthor: Speedie » Sat Dec 09, 2023 5:04 pm
Have done two tanks with por15. Still going strong with zero
problems years later. But you have to follow the instructions to
The letter!
Paul
Kev1R
#6 PostAuthor: Kev1R » Sun Dec 10, 2023 12:19 am
From the dozens of reviews / comments on the web there seems to be 2 categories of POR15 users - those that it works for and those that it does not. Unfortunately this year I fall into the latter category when used on an S3 tank. Apart from the 70% or so of the liner that delaminated I cannot find anything that removes the remnants so you can start clean again. Nothing seems to touch it. I would agree with Adrian H and only be tempted to use a liner if you absolutely have to. The seam on mine had developed a weep so maybe I should have had it rewelded / brazed instead, but not so critical now as I have since acquired another tank.
010
Stugill
#7 PostAuthor: Stugill » Sun Dec 10, 2023 8:10 am
Kev.
That must have been a 'mare.
I agree that the reviews were mixed and I did it with an element of trepidation, tbh I went overboard with cleaning it out and then getting it dry, this may have lifted me into the lucky %.
Stu
Kev1R
#8 PostAuthor: Kev1R » Mon Dec 11, 2023 8:50 pm
Yes Stu it was indeed- especially as I had just had the tank painted! - and frustratingly the remedies that sound most plausible that I have seen are pretty much all going to entail sacrificing the paintwork. For the time being I shall just own it as a work of art as the paint job is great!!
010
#9 PostAuthor: ADRIAN H » Fri Dec 15, 2023 9:40 pm
Kev1R wrote:Yes Stu it was indeed- especially as I had just had the tank painted! - and frustratingly the remedies that sound most plausible that I have seen are pretty much all going to entail sacrificing the paintwork. For the time being I shall just own it as a work of art as the paint job is great!!
Had good results removing a lining with FROSTS, 2 x 5litres of Tank STRIP ( recommended by FROSTS to remove POR15). Tank filled and left for 4 hours, drained back into can and rinsed. Repeat next day different orientation drained, rinsed, repeated from memory over 10 days. But I can’t be 100% positive it was POR15 in the tank.
Users browsing this forum: No registered users and 109 guests
