Front part of brake caliper marked B for Z1B
shaggy
#1 PostAuthor: shaggy » Thu Dec 07, 2023 7:26 am
Anyone got a spare Front part of brake caliper marked B for Z1B my bleed nipple has snapped off and isn’t coming out
Re: Front part of brake caliper marked B for Z1B
#2 PostAuthor: Z1streetfighter71 » Thu Dec 07, 2023 7:57 am
As a fix for the one you have, a left handed drill bit normally does the trick, heat the caliper up oven/torch first. If you do get a new caliper ill buy the one you have off you if you want to sell it on.
shaggy
#3 PostAuthor: shaggy » Thu Dec 07, 2023 8:19 am
Only need the front half nipple will not come out and now and has part of an easy out snapped in it
#4 PostAuthor: Z1streetfighter71 » Thu Dec 07, 2023 12:58 pm
shaggy wrote:Only need the front half nipple will not come out and now and has part of an easy out snapped in it
ouch...
BAFF1960
#5 PostAuthor: BAFF1960 » Fri Dec 08, 2023 9:20 am
Hi.
Snapped easy outs can be removed with the correct tooling though not easy. I've done it on aircraft fasteners where there's no other option for disassembly.
shaggy
#6 PostAuthor: shaggy » Sat Dec 09, 2023 11:23 pm
Now got an engineering company going to sort it for me
#7 PostAuthor: paul doran » Sat Dec 30, 2023 10:54 am
Easy outs are never a quick fix I find they snap too easily
shaggy
#8 PostAuthor: shaggy » Mon Jan 15, 2024 7:23 am
All fixed by Count engineering in Doncaster
