Fuel Tap Blanking Cap
bulldogbobby
#1 PostAuthor: bulldogbobby » Wed Jan 10, 2024 3:22 pm
I need to remove the fuel tap from my A4 tank and blank the threaded entry off to clean and treat the tank internally and from what I've found, I believe that the thread for the fuel tap is 22mmx1.0mm? Struggling to get anything like this - could always use a tapered rubber bung but I wondered if anyone else has had a previous (better) solution?
Cheers in advance for any help
Re: Fuel Tap Blanking Bolt
#2 PostAuthor: chrisu » Wed Jan 10, 2024 4:16 pm
i used a tapered rubber bung to block it up temporarily
Gus
#3 PostAuthor: Gus » Wed Jan 10, 2024 4:32 pm
"Set the GRINDER on it"
#4 PostAuthor: ADRIAN H » Wed Jan 10, 2024 5:59 pm
Rubber bung is the best method.
KevinH
#5 PostAuthor: KevinH » Wed Jan 10, 2024 7:22 pm
An old fuel tap in the off position works a treat
bulldogbobby
Re: Fuel Tap Blanking Cap
#6 PostAuthor: bulldogbobby » Thu Jan 11, 2024 10:39 am
Thanks as always for all the help and thanks Gus - Cap on order :up
Users browsing this forum: No registered users and 106 guests
